KVM Comet 10 Pro video okay - no kb/mouse [FreeBSD]
Hi team
has anyone managed to get a Comet 10 pro working on FreeBSD.
i can see usb mice / keyboard connect and disconnect live over console but - no luck with KVM.
any ideas?
root@freebsdbox:~ # usbconfig
ugen0.1: at usbus0, cfg=0 md=HOST spd=SUPER (5.0Gbps) pwr=SAVE (0mA)
ugen0.2: at usbus0, cfg=0 md=HOST spd=HIGH (480Mbps) pwr=ON (500mA)
ugen0.3: at usbus0, cfg=0 md=HOST spd=FULL (12Mbps) pwr=ON (100mA)
have you tested the COMET 10 Pro with any other computer besides this one? I don’t know the status of your freebsdbox, but maybe try “live” booting (off a USB, or disc? or even pixi-boot?) and see if the OS would have anything to do with it? If you try the COMET but change the OS and/or controlled-computer it might isolate any USB-related issue?
Disabled MSD
yes disabled, have also altered EDID to see if that makes any difference still not detected by remote computer.
however a usb cable swap has solved the issue, thank you both for your support.
