there is a panel on the left in the "Toolbox" section which has a set of 8 default shortcuts (print screen, ctrl + Alt + Del etc...
is it possible to add/update these somehow?
Will be supported in version 1.3, expected at the end of May
@robotluo will it also support shortcuts for macOS? Currently I see it's only windows shortcuts even on the client for macOS
Maybe some functionality to place such shortcuts on the main toolbar? (like alt+crl+del?)
Can You also provide more EDID predefined devices (3840x2160 30Hz well known monitors not just GLKVM?)
Thank You
I just tried 1.3. Seems we can't use Dell's 'Fn' key as part of the shortcut keys.
I tested that Fn cannot be used, it will be fixed in the next version
Thanks Robotluo!
