L-MT3000 Beryl AX + E3372-325
Good day,
I’m trying to make GL-MT3000 Beryl AX working with Huawei E3372-325 4g modem with zero luck.
E3372 is working just fine when it’s plugged in a laptop, but doesn’t work when plugged in Beryl AX. It keeps blinking green and red. I’ve tried rebooting Beryl AX and the issue with the the next Beta OS (4.2.3).
I also changed router address to 192.168.10.1, but still no luck.
Sharing logs bellow
kern.info kernel: [ 591.056827] usb 1-1: new high-speed USB device number 4 using xhci-mtk
kern.info kernel: [ 591.214174] rndis_host 1-1:1.0 usb0: register ‘rndis_host’ at usb-11200000.xhci-1, RNDIS device, xx:47:b5:c4:e5:yy
daemon.notice netifd: Interface ‘tethering’ is enabled
daemon.notice netifd: Network device ‘usb0’ link is up
daemon.notice netifd: Interface ‘tethering’ has link connectivity
daemon.notice netifd: Interface ‘tethering’ is setting up now
daemon.notice netifd: tethering (21998): udhcpc: started, v1.33.2
daemon.notice netifd: tethering (21998): udhcpc: sending discover
user.warn : skip line without ‘=’ Default
kern.info kernel: [ 593.204471] usb 1-1: USB disconnect, device number 4
kern.info kernel: [ 593.209578] rndis_host 1-1:1.0 usb0: unregister ‘rndis_host’ usb-11200000.xhci-1, RNDIS device
daemon.notice netifd: Network device ‘usb0’ link is down
daemon.notice netifd: Interface ‘tethering’ has link connectivity loss
daemon.notice netifd: tethering (21998): udhcpc: read error: Network is down, reopening socket
daemon.notice netifd: tethering (21998): udhcpc: bind: No such device
daemon.notice netifd: Interface ‘tethering’ is now down
daemon.notice netifd: Interface ‘tethering’ is disabled
user.notice mwan3[22748]: Execute ifdown event on interface tethering (unknown)
user.notice firewall: Reloading firewall due to ifdown of tethering ()
kern.info kernel: [ 594.128070] usb 1-1: new high-speed USB device number 5 using xhci-mtk
kern.info kernel: [ 594.288043] usb-storage 1-1:1.0: USB Mass Storage device detected
kern.info kernel: [ 594.297248] scsi host0: usb-storage 1-1:1.0
kern.notice kernel: [ 595.316366] scsi 0:0:0:0: CD-ROM Linux File-Stor Gadget 0310 PQ: 0 ANSI: 2
This might get you closer:
Thank you. That’s the reason explained - Pavel Piatruk' tech & personal blog
The issue was fixed in new firmware dated January 2023 - 3.0.2.62 (H057SP9C983), but for some reason my modem wasn’t receiving it.
I have the same modem and it’s also not receiving any updates. It’s stuck on 3.0.2.61. I kept it on overnight for a couple of days and it didn’t update (despite having the “auto update at night” option on). Manual check shows there are no updates…
Have you managed to update yours? How?
Is there any update on this topic? Im stuck with the same problem and i couldnt find a way how to manually update the firmware on the E3372-325.
Is there maybe any other USB Dongle that would? I didnt expect it will be this hard to get it working.
Having the same issue here.
Firmware stuck on 3.0.2.61
→ if someone can give any instructions/links how to get and flash
the 3.0.2.62 (H057SP9C983), that would be great!
I would be willing to rip open the device for the update.
Just need to get it working somehow.
Can’t believe it’s that hard to get a new (already existing) firmware version…
Hi, any update for this?
Ok, I answer my self, working following this steps:
