leone88
Hi everyone. Thanks for the forum.
I have a problem.
I have to use this configuration:
- Gl. Inet GL-MT300N-V2 (or GL-AR300M16?) + modem USB with sim (it’s OK Alcatel IK40V-2BALIT1 ? 4G-LTE )
- Normal Tplink connected to gli. Inet via Wan with ethernet, after tplink give at home internet with ethernet and wifi.
Now. I have read many articles on the internet but everyone says different ways. Or say how to do ipsec server.
While I only need L2tp Ipsec / psk Client on my gl.inet
I have this data to access the server:
L2TP IPSEC PSK
Server address
Precompiled key
User
Password
Is all this feasible? What I do?
I did the tests on the L2tp ipsec/psk server with my Android smartphone and it reaches 60mb / s. Can gl.inet reach this speed or have limits?
Thanks a lot
alzhao
2
Unfortunately L2TP via IPsec is not working good on the router. Even it works the speed will be several Mbps only.
We suggest you to use OpenVpn or wireguard.
leone88
3
Ok thanks.
But L2tp is faster than openvpn…
Johnex
4
And wireguard is faster and more secure than L2tp
You can check benchmarks here:
alzhao
5
With IPSec, L2TP will be no faster.
leone88
6
Yes. But I need L2tp. Which router do you recommend? Or what is the best economic solution to use L2tp?
Thanks so much
alzhao
7
If only l2tp you can use any router. You can set up in luci. Just no IPSec.
leone88
8
Please. Is there a guide about it? On routers gl. Inet? Thank you
alzhao
9
Luci->network->interfaces
Then go to WAN and edit
zurapa
10
Man! I recomen MikroTik. L2TP/IPsec client wokr very very stable!
