Lan conection help
Hello to everyone…i am new on it…i just buyed 3 of GL.iNet GL-MT3000 (Beryl AX)…and i configurate with talescale…to use nertfli etc
I conected this divice with cable via ethernet from my isp router to wan port of GL.iNet GL-MT3000 (Beryl AX)…and from lan port of GL.iNet GL-MT3000 (Beryl AX)to tv…so it connect to internet succesfully but after 40min it disconect and no way to work again…from wifi its work well…any sugestión if i have to configure via advance configure from luci panel?please
Thanks to all in advance…
please follow these steps to provide additional information about your issue: How to get support quickly
Can you check the firmware version and log?
For the log you can get from the web panel when you connect via wifi.
logread.tar (381 KB)
Thanks for your replay…
Here goes what u asked
I can see your WAN breaks once. But this is not what you mentioned.
For the LAN, I can see you have 100mbps device connected. Mabe it is not compatible with your device?
As you said wifi is working OK, so the router’s system is still alive.
Have you tried to unplug and replug the lan cable to check?
Yes I did and yes it work for several time,and works for mins/hour and same result…its samsung TV…and when i plug directly from my isp provider to tv via cable yes its work without problem…so something wrong on these GL.iNet GL-MT3000 (Beryl AX)
