I purchased a GL-MT300N-V2 to solve a problem: I have a 3d resin printer which has LAN network connectivity (rj-45) but I don’t have any cable near it and I found the printer needs to be in the same subnet as the PC running the slicing software.
Using WDS is okay but I noticed a bunch of my other wifi devices now connect to the Mango and I don’t want that. Is there a way to setup the Mango where it would only server the printer and still be in the same subnet as my main router?
You can connect the Mango in repeater mode to your main router and disable wifi. It will act as a wifi client, giving wifi to anything connected to the LAN ports.
Can you try setting up extender which will connect your printer to the same subnet.
But I am not sure if it will reconnect if you disable wifi. If not you can change a long key and make the SSID hidden so that it will not be find by other devices.
I must say after a few days of usage, that the wifi connection is very flaky even if the router is 10 feet away from my main router in direct LOS (getting a 16% packet loss and latency from 7ms to 3400ms is not friendly when your traffic is mainly udp). Is there anything I can check or change in the config to get a better and stable connection?
Thank you for your help.
How can I get the sta config, I guess I have to ssh to the mango but I haven’t found yet what is the proper command to run once connected.
