LAN traffic not routed over VPN
Just received a new Mango router (GL-MT300N-V2), fab bit of kit. Setup a VPN client as a Global Proxy.
Any client that connects via the WiFi is routed via the VPN. Great !
Any client that connects via the LAN port is NOT routed via the VPN. Sad!
I've tried setting the global option "Block Non-VPN Traffic" which makes no difference, and also the VPN option "Allow Remote Access LAN", which also had no effect.
Can anyone tell me how I get the LAN clients traffic routed via the VPN ?
Thanks.
Phil.
However, this could be just me..., I think the IP masquerading was tricking me into thinking the traffic was bypassing the VPN tunnel...
The client of the Wi-Fi and LAN both in same net-bridge, as well as all client of these 2 interfaces are same one LAN.
Could you upgrade the latest firmware and reset, then try it one more time?
