I think DNS are leaking on router AR300M(Version 3.203). Kill switch is on. If I disable VPN(open VPN) or VPN drop and try command nslookup result looks like this:
***nslookup
Server: 127.0.0.53
Address: 127.0.0.53#53
Non-authoritative answer:
Name:
Address: 142.250.181.238
But it should look like this:
*nslookup google
Server: 127.0.0.53
** server can’t find google REFUSED
Second question?
Which firmware use to install Open WRT from Index of /releases/21.02.0/targets/ath79/nand/ site.?
glinet_gl-ar300m-nand-initramfs-kernel.bin or glinet_gl-ar300m-nand-squashfs-factory.img or glinet_gl-ar300m-nand-squashfs-sysupgrade.bin
