I’ve tried this on both Mango mt300n-v2 and ar300m
I’d like to set the middle LED to be on for OpenVPN & Wireguard (it seems once I assign an LED to one of them it can’t be assigned to both) - is it possible to have it trigger by either (the only difference option dev ‘wg’ or ‘tun0’) = is it possible to have it work with both?
The other alternative is just to use a different LED for wireguard - but I notice when I set the red LED it means I can no longer see the reset light for factory resetting etc (and the left is reserved for power)
Hoping this is possible / someone knows a method ![]()
