LED status GL-MT2500A
The blue LED is still flashing blue.
According to this manual it should be white.
Is this correct?
@Confucius which firmware version, as I'm running 4.6.4 and mine is white.
It's on V4.6.4.
Mines white on 4.7 beta 2
Does the flashing indicate that I have not set it up correctly?
Difficult to say, what have you configured it as?
Flashing blue mean do not have Internet.
If you do have, maybe it is because of ping is blocked.
