Good evening to all, since I updated the firmware (the latest available 3.009.-1205) The status LED of my router ar 300m does not flash anymore even if it works properly. Does it happen to you?
You mean wifi LED is not working?
It is a bug. The led name has changed.
From the advanced interface can I solve it in any way? Or I await the next updates (it is not essential all in all)
Yes, you can fix it in luci. Please go to LUCI → System → LED Configurations. Select the “LED Name” to gl-ar300m:green:wlan
Perfect, edited and working everything. Thanks for the technical support
