has anyone got a copy of the opkg packages for LEDE 2.27 for an AR150?
we are currently unable to install or update packages, we tried looking in glinet github but it looks like they have been removed
thanks
thanks
White (GL-AR150)
Memory / Storage DDR2 64MB / FLASH 16MB is too small ,maybe could not to install or update packages.
If upgrade ,suggest Brume (GL-MV1000)
I think the issue is that the opkg distribution package source URL for LEDE 2.27 is no longer available - 404 Page not found - GL.iNet returns a 404, but I found the packages are still available within http://download.gl-inet.com/lede/2.27/ar71xx/generic/.
As of January 2018, both the OpenWrt and LEDE projects agreed to re-merge back under the OpenWrt name.
The current old-stable version series of OpenWrt is 18.06, with v18.06.9 being the last service release of the series. It was released on 9 December 2020. No new releases in this series are expected.
For security ,you need to upgrade.
https://dl.gl-inet.com/firmware/ar150/v1/
lede-ar150-2.271.bin
openwrt-ar150-3.105.bin(suggest)
2.x firmware is not supported and repo is removed.
