Hello
I have a question regarding the WPA configuration options in the FLINT 2 router that I have. Prior to the acquisition of GL-MT6000 Flint 2, I used FritzBox 7590 AX router and the WPA Encryption using this router was set to WPA2+WPA3. My new devices connected to this router using Wi-Fi 6, and used WPA3, but older devices not capable of using Wi-Fi 6 and the modern encryption, used the WPA2 method considering the network as Wi-Fi 5
Samsung Galaxy Note 9 for example is one of those devices not capable of connecting using WPA3, hence used WPA2.
I want to replace my FritzBox with my new and shiny GL-MT6000 Flint 2, and I have tried the latest firmware and then the latest beta 4.7.0, and in none of these versions I was able to configure the Flint 2 as my FritzBox. That is, if I configure the Flint 2 to use WPA2-PSK/WPA3-SAE then my Samsung Galaxy Note 9 and older devices can never connect to my Flint Wi-Fi. Only modern devices which consider this network as Wi-Fi 6 as well
Since I currently have various devices that do not support WPA3, I have set the Wi-Fi security to a transmission/mixed mode, WPA2-PSK/WPA3-SAE, which theoretically means that that at least all of my devices that already support WPA3 can use it and the devices that only support WPA2 can continue to use WPA2, but no legacy device can even connect using WPA2. What am I doing wrong? Currently I had to select WPA2-PSK to let my legacy devices connect.
