I’m opening some ports for forwarding to an asterisk server (as usual 5060 and 10000)
VOIP provider is recommending to limit access to asterisk only to their IP.
How do I limit the access to a single WAN IP or to a range ?
Thanks
Dado
To be clear, you want to limit only one IP or IP range accessible to the port 5060 and 10000 on WAN?
You can go to Luci->firewall->traffic rules, find your port forward then edit it. You will have a lot of options.
More advanced, you can try some IP tables skills. Like this one: https://www.cyberciti.biz/faq/iptables-block-port/
