I have been working on two WANs (ISPs) but configuration on one router does not work.
So I am trying to work with two routers.
GL-AX1800 (192.168.8.0/24):
WAN: ISP-AGL-AXT1800 (192.168.9.0/24):
WAN: ISP-B
I want:
LAN will go through WAN of the same router, i.e.
LAN on GL-AX1800 will go through WAN on GL-AX1800 (ISP-A) and
LAN on GL-AXT1800 will go through WAN on GL-AXT1800 (ISP-B) -
clients on both LANs could access each others. i.e.
192.168.8.x
can access192.168.9.x
and
192.168.9.x
can access192.168.8.x
Should I connect two routers with a cable LAN to LAN port?
How should be the configuration afterwards?
Thanks.
