Linux Kernel Flaw "NoisyTCP" (CVE-2026-99288) – Please Patch Firmware & Check WAN Ports!
Hi GL.iNet team and community,
A critical Linux kernel vulnerability called NoisyTCP (CVE-2026-99288) was just disclosed, with a public proof-of-concept exploit already available. Since GL.iNet firmware is built on OpenWrt (using Linux kernels like 5.4, 5.15, and 6.6), our routers are affected.
What is the issue?
A race condition in the Linux TCP stack (with SYN cookies enabled) allows unauthenticated remote attackers to crash the router (Kernel Panic / reboot) via crafted IPv4 packets—if the router has an exposed TCP port on the WAN and uses multiple CPU cores / RPS.
(Note: Standard port forwards to LAN devices do not make the router itself vulnerable, only the target device behind it.)
Request to GL.iNet
Could the team please backport the upstream fix (from Linux 6.12.117 / 6.18.63 / 7.3.4) into upcoming firmware releases for active router models?
Quick Workaround for Users (via SSH)
  1. Close WAN TCP ports: Make sure Remote SSH / HTTP / HTTPS access from WAN is disabled in the Admin Panel / LuCI firewall. Use WireGuard (UDP) for remote access instead.
  2. If you MUST keep a WAN TCP port open (e.g., OpenVPN over TCP): Temporarily disable SYN cookies until a firmware patch is released:
    bash
    sysctl -w net.ipv4.tcp_syncookies=0
    echo "net.ipv4.tcp_syncookies=0" >> /etc/sysctl.conf
    Use code with caution.
Thanks!
Thanks for bringing this to our attention. We've asked our R&D team to investigate this vulnerability and work on the necessary fix.
