I’m essentially brand new here, and brand new to the idea of load balancing, so please forgive my ignorance.
I’ve been told the GL-AR750S EXT can load balance. Here’s what I’ve got:
2 cell phones – roughly equal on the same network
A 4-port hub to which I can connect both phones
A GL-AR750S EXT router (FWIW I also have a GL MT300N-V2 if THAT router would be more usable for load balancing)
I found a sort-of set of instructions at github – “OpenWrt - GL.iNet AR-750 Use LAN port as 2nd WAN in order to use Mwan3”
But I have no idea what they’re telling me. Why am I using a LAN or whatever to load balance two cell phones? The whole thing seemed very arcane and confusing.
So, CAN I load balance with the hardware I have? One phone is always plugged into the router, the other would come and go – so things need to work when there’s only 1 phone plugged in (I know it won’t load balance without 2 phones, but it can’t turn into a brick)…
If so, is there a reasonably simple, idiot-proof set of instructions for exactly what I have to do to make this work?
