Can we use local (client) camera feed as usb device for host (attached deivce) just lke OBS studio on GL-RM1PE-135
Do you mean make the camera on the computer you are currently using to operate the GL-RM1PE (the control end) available for use by software on the remote computer being controlled (the controlled end)?
If so, we do not currently support this; it is under development.
I need the same feature. To use local camera on remote computer. To attend meetings.
+1 this would be an amazing feature and set it apart from the competition
This would be the workaround for Webcam passthrough. If the team could make it possible to connect a computer to USB port on KVM and allow to stream a app through for webcam
