Thank you! I found the manual for EC25 which had the information I needed.
First, I executed AT+COPS?
to get the current setting, which for me returned:
+COPS: 0,0,"ice+",7
The syntax for the command is <mode>[,<format>[,<oper>][,<Act>]]
. I think 7
means LTE
for my EC06, I’ve configured it to only connect to LTE.
After a bit of trial and error, this command seemed to do the trick, returning OK
AT+COPS=4,0,'ice+',7
I used 4
as mode, which falls back to automatic mode (0
) if the operator is not found.
Note that the command only worked when I used single quotes. For some reason, double quotes resulted in +CME ERROR: 22
, meaning “not found”. Took some experimenting to figure out.
A final AT+COPS?
command confirmed that the change was saved:
+COPS: 4,0,"ice+",7
Hopefully this is useful information for someone else out there
Suggestion to GL-iNet:
It would be nice to have this as an AT command shortcut, similar to “Set band”.
