I have recently purchased Spitz AX, I see I can lock to specific cells but I just want to lock to 4g LTE and don't want to use 5g NSA because 5g NSA isn't fast in my area.
Thanks
You can achieve this by blocking all 5G bands in band masking, see: Cellular - GL.iNet Router Docs 4
It worked, thanks both.
I wonder if it would be possible to program the Modem to allow locking to an LTE Tower as well as another 5G NSA/SA Tower.
My SIM needs LTE to register with the ISP and the best 5G NSA signal is from a different one.
Hello everyone, I have a similar problem.
I also have 5G limitations in my area and I would like it to only connect to 4G/4G+ for more stability.
This only happens if I lock tower on a specific cell. But if I do this and select only LTE bands, i get NSA automatically and I don't understand why.
Could you please help me out? Thank you.
Firmware Type 0701release3
Module Version RM520NGLAAR03A03M4G
+QCAINFO: "PCC",1650,100,"LTE BAND 3",1,6,-86,-12,-51,7
+QCAINFO: "SCC",638016,8,"NR5G BAND 78",621
+QCAINFO: "SCC",517210,3,"NR5G BAND 38",2,621,0,-,-
OK
