Log Storage - Android App What is V4?
Hi all
A question on the logs being collected in the android app if I may.
What is V4 recording? I cannot see a matching log in the main windows GUI (I have System, Kernel, Crash, Cloud and NGJINX). None of the data or commands matches what is recorded in V4.
I am slightly concerned as opening V4 log reveals constant Request Data: {jsonrpc:2:0, method: call, params followed by a reply with huge lists of my parameters (including passwords!) displayed in plain text.
This makes me very nervous. Could someone advise please.
I have managed to find i screenshot that doesn't give away all my passwords. As you can see the logs are being flooded every few milliseconds.
Grateful for any advise
@bruce might you have a look?
These are the APIs, the glinet management APP gets the router configuration from APP to router firmware via the APIs (in fact is the https request)
I have checked it, only the WiFi key displayed in plain text, the login or other password cannot be displayed or in ciphertext.
If you login the GL WebUI, the WiFi key also display in plain text:
Thank you Bruce. Being new to this it was quite a fright to see this much data 'exposed'.
