Logging on BE9300 Flint 3
We have a Flint 3 client insisting on no logs or record of offline clients. So we have tried to make this happen - but with mixed results.
We set cron job for ubus call gl-clients remove_offline to run every five minutes, which appears to wipe the offline clients list.
The GL admin panel has entries for system, kernel, crash, cloud & NGINX logs.
We ran /etc/init.d/log stop and /etc/init.d/log disable to disable system log.
Disabled NGINX logging with error_log off in /etc/nginx/nginx.conf
And we set a cron job /bin/dmesg -c > /dev/null every five minutes to keep the kernel ring buffer cleaned up.
Then rebooted Flint 3. Now the WiFi keeps dropping connections. I tested a few ideas why this may be happening, but have been unable to pin down the precise cause.
Maybe there is a better way to keep those GL admin panel logs clear?
I put some effort in to this and learned a bit.
Admin panel system log does not appear to rely on ubus log read as I initially thought, instead it seems to fetch logs via /www/cgi-bin/glc to libgl_log.so.
Ultimately I wrote a little script that seems to do what was needed:
#!/bin/sh
# Persistent 30-minute wipe script for Flint 3
# Run in background to avoid blocking boot
while true; do
    # 1. Clear NGINX log
    [ -f /var/log/nginx/error.log ] && > /var/log/nginx/error.log
    [ -f /var/log/nginx/access.log ] && > /var/log/nginx/access.log
    # 2. Clear kernel log
    dmesg -c
    # 3. Restart log daemon to clear system log
    /etc/init.d/log restart
    logger -t SYSTEM "Logs wiped"
    # 4. Remove offline clients from admin panel list
    # Minimal local record
    echo "$(date) - logs & offline clients cleared" >> /root/mirage.log
    tail -n 100 /root/mirage.log > /root/mirage.log.tmp && mv /root/mirage.log.tmp /root/mirage.log
    # Sleep 5 minutes
    sleep 300
done
Made it executable, then call it in /etc/rc.local so it persists across reboot.
So far it seems to be working well. Router stays alive, WiFi doesn't drop, WireGuard tunnel stays alive …
Anything I am missing?
We do not actually recommend that users disable these features or close records.
Sorry, we can't check if it's correct.
