Is there a way to login into the AdGuard Home console/web without having to login first into the Router GL GUI and having to press the Settings Page link?
Yes, but not with the default configurations of Nginx; You need to slightly modify Nginx in order to be able to directly log into AdGuard.
Thank you, do you have some info or links to look for details on how to do it?
Links are the same as in the last topic you posted about AGH.
