I am having a problem logging into the ‘More settings/Advanced’, that is, into openwrt as root.
I have already successfully entered the password for the admin page, but openwrt will not let me in as ‘root’, with the same password.
It says: “Invalid username and/or password! Please try again.”
I have changed the admin password at least two times, and it is not the default ‘goodlife’.
The username appears as ‘root’. My usual admin password does not work here.
Resetting the unit would cure this problem, but I would rather not do that, yet,
I have quite a lot of other settings including a Wireguard server running, and these would be lost.
It looks as if ‘root’ does not have the admin password.
Can you duplicate this problem and/or suggest a fix?
It is possible that I changed root’s password from within openwrt.
