how can i access the interface panel on the web wan port 192.168.8.1 from the local pc
the pc uses a 192.168.0.1 subnet
is it possible to access?
Not sure what you’re using it for, can you simply describe your network topology?
Normally you only need to open port 80 in the firewall page, but your description involves multiple subnets and I need to know your connection topology.
main router 192.168.0.1
GL.net on wan on 192.168.8.1
desktop pc via lan to 192.168.0.1
i can’t get into 192.168.8.1
I can only if I connect the desktop to glnet wifi
First, you should open port 80 on glinet router.
And then, you can manage the router through the router’s WAN IP, note that it is not 192.168.8.1
ok perfect thamks ok perfect thamks
one more thing, is it possible from the 192.168.8.1 network to go to a device in the primary network 192.168.0.1?
Open the port on the firewall of the corresponding device, and you can access it directly.
and to open all ports be transparent to my main router?
You need to open the access device, not the main route. For example, if you set the network to a home network on your PC, your device is still secure because you still have the firewall protection of the primary route
to have access to my entire home network which port should I open the one of the main router 192.168.0.1?
You don’t need to do anything with the main route, and if the device on the LAN doesn’t have security Settings, you can access it directly.
If the device has security Settings, you need to set security policies on the device to be accessed.
if I’m connected to 192.168.8.10 ect… and I want to go to a device that is present on 192.168.0.10 ect… I don’t see the device
dmz ON 192.168.0.1 ?
