Login to sub nodes in mesh mode
hey!
I have two router in mesh mode, and I can see the main node and the sub node when I log into the main node - my question is - how can I log into the sub node and update it if I need to?
Thanks in advance
B2200? B1300?
In B2200 you cannot login to sub node.
Hey… I actually ending up getting the b1300 to be a subnode for b2200. I can log into the subnode via ssh once I knew the ip.
Yes you can use ssh.
This should be disabled in B2200
