I have the flint 2 connected to my primary router and when I activate Nordvpn with Wireguard shortly after I lose wifi connection.
I noticed that this doesn't happen if I use Openvpn.
What could be the cause? Maybe Adguard?
When enabled the WG client (NordVPN), will the WiFi be dropped the connection from clients (such as phones, laptops, etc.) that have been connected to Flint 2 WiFi?
If clients WiFi is disconnected, can it scan to the Flint 2 WiFi SSID and reconnect in WiFi settings list?
Will there be the same problem with the 2.4GHz and 5GHz WiFi of Flint 2?
When the issue reproduced, is the Internet (VPN) connection normal to the Flint 2 client wired?
Is Flint 2 connected to the primary router via wired or via repeater?
What is the firmware version of Flint 2?
Please export the log and share it with me through PM when the issue reproduces.
- Yes
- Yes, but with limited connection.
- Yes
- After a while with limited connection
- Connected via wired
- 4.7.7
Thank you.
Thanks for your reply.
One more confirm, if the issue reproduced, can the wired clients access Internet?
Please share the issue syslog and the router backup configuration.
It seems to be working now.
Thank you.
May I know what configuration did you modify to improve this?
I don't know. It just worked without doing anything.
