What are these Pins used for ?
How can we use them for Bitbanging like GPIO ?
# P4RX+ ?? p36
# P4RX- ?? p37
# P4TX+ ?? p38
# P4TX+ ?? p39
# P0RX+ ?? p41
# P0RX+ ?? p42
# P0TX+ ?? p43
# P0TX+ ?? p44
# P4RX+ ?? p36
# P4RX- ?? p37
# P4TX+ ?? p38
# P4TX+ ?? p39
# P0RX+ ?? p41
# P0RX+ ?? p42
# P0TX+ ?? p43
# P0TX+ ?? p44
And,
Where is GPIO25 pin# ?
Is so, can this be disabled to use these port pins for Bitbanging ?
PO and P4 is for Ethernet. I don’t think it can be used as GPIO.
there is no GPIO25
But, any way to use P0 + P4 ?
Hi, I’ve been wondering the same thing and after some research I ended up ordering some “MagJack” ethernet connectors with built-in resistors, LEDs, and pulse transformers. They are through-hole parts that allow you to simply connect wires from the P0/P4 pins (Or others if you don’t have an ethernet tile) to them for use. I got them at Element14/Farnell and the mfr. part # is SI-52008-F and were $3.74 each. HTH, been a while since the question was posted.
-Larry
