Starting today, I’m having a bit of trouble with my Comet Q. The remote access is working fine, but the local access isn’t. This issue is affecting both web and app access, as well as my MacBook and iPhone. For the last couple of days, since I configured it, it was working perfectly from all access points. And no, it’s not a router isolation problem because I’m accessing other devices like my Linux server and NAS using SSH.
Instead of entering IP address which will often change, you should enter glkvm.local instead, which resolves locally through mDNS.
If you have more than one glkvm, you can change this hostname in settings.
Hi, thanks for the feedback. Could you check the current IP address of the Comet Q in your router and try accessing it directly?
You can try glkvm.local for local access.
The issue is resolved now, the issue was with my Mac being unable to resolve local addresses. Thanks for all the guidance.
