I enabled IPv6 from the modem interface, router says it got IPv6 address, but IPv6 is not routable
I tried both cdc-wdm0 and ttyUSB3, both have the same issue (got IPv6 address, provided IPv6 to LAN, but IPv6 is not routable / failing neighbor discovery on default gateway)
from SSH
root@GL-X750:~# ip -6 addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 state UNKNOWN qlen 1000
inet6 ::1/128 scope host
valid_lft forever preferred_lft forever
2: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 state UP qlen 1000
inet6 fe80::9683:c4ff:fe0a:3415/64 scope link
5: wwan0: <BROADCAST,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 state UNKNOWN qlen 1000
inet6 2607:fb90:47c3:5723:dcec:3bff:fee1:d357/64 scope global noprefixroute
inet6 fe80::dcec:3bff:fee1:d357/64 scope link
8: br-lan: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 state UP qlen 1000
inet6 fd25:a9c8:2d04::1/64 scope global noprefixroute
9: wlan1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 state UP qlen 1000
inet6 fe80::9683:c4ff:fe0a:3416/64 scope link
10: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 state UP qlen 1000
inet6 fe80::9683:c4ff:fe0a:3417/64 scope link
valid_lft forever preferred_lft foreverroot@GL-X750:~# ip -6 route
default from 2607:fb90:47c3:5723::/64 via fe80::b0ec:1041:65e2:7049 dev wwan0 proto static metric 512 pref medium
2607:fb90:47c3:5723:xx dev br-lan proto static metric 1024 pref medium
2607:fb90:47c3:5723:xy dev br-lan proto static metric 1024 pref medium
2607:fb90:47c3:5723::/64 dev br-lan proto static metric 128 pref medium
2607:fb90:47c3:5723::/64 dev wwan0 proto static metric 256 pref medium
unreachable 2607:fb90:47c3:5723::/64 dev lo proto static metric 2147483647 error 4294967148 pref medium
fd25:a9c8:2d04::/64 dev br-lan proto static metric 1024 pref medium
unreachable fd25:a9c8:2d04::/48 dev lo proto static metric 2147483647 error 4294967148 pref medium
fe80::/64 dev br-lan proto kernel metric 256 pref medium
fe80::/64 dev wlan0 proto kernel metric 256 pref medium
fe80::/64 dev wlan1 proto kernel metric 256 pref medium
fe80::/64 dev eth1 proto kernel metric 256 pref medium
fe80::/64 dev wwan0 proto kernel metric 256 pref medium
default via fe80::b0ec:1041:65e2:7049 dev wwan0 proto ra metric 1024 expires 65382sec hoplimit 255 pref mediumroot@GL-X750:~# ip -6 nei
2607:fb90:47c3:5723:xx dev br-lan lladdr 8c:8c:aa:17:xx:xx STALE
2607:fb90:47c3:5723:xy dev br-lan lladdr 8c:8c:aa:17:xx:xx STALE
fe80::3053:51dc:b625:73e dev br-lan FAILED
fe80::e869:d3b3:8ade:f1e1 dev br-lan lladdr 8c:8c:aa:17:xx:xx STALE
