I have per now always connected only by wifi. Now I wanted to use LTE via the box. I use a German Telekom SIM card just in Sweden. I only reach 10Mbps. Over my cell phone I reach but 160 Mbps in the same place!
On my cell phone I had to change the network provider, in this case to “Telia”.
How and where can I do that with the X300B? Where do you even see which network you are dialed into?
I had meanwhile updated to version 4. now I get 22M! And the provider “Tele2” is now also displayed to me, which uses the box.
With “Tele2” on
Mobile phone (IPhone 14 pro) I also only reach 22M - so that’s the same.
If I set the cell phone to the provider “Telia”, I get 160M on the cell phone.
So I have to switch the box to “Telia”. How do you do that? Do you have to change the “band” for this? On which “Band” can I find “Telia”? The “band” are only numbered on the box and have no name.
The AT command mentioned above results in “Error” as the output.
