just restored as factory reset this plug.in is not installed by default luci-i18n-mwan3-it. what is it for?
This is a mwan3 language pack (probably Italy), do you need this plugin?
Is the router AX1800, and the firmware v4.7.0?
Fint2 firmware 4.7
The "luci-i18n-mwan3-it" is on the Flint 2 repo, both the 4.7.0-op24 and stable 4.7.4.
op24-4.7.0:
4.7.4:
When installing plug-ins, the language pack will not be installed by default, and you need to install it manually.
but if by default the man1 port with wan is not installed it works as a load balance and if I install the load balance plug in it stops working
If you install the plugin mwan3
and then WAN 1 will be stopped to work?
Please check the WAN port status on the GL GUI -> Network -> Network Port Management -> WAN, and please re-plugged the network cable, export and share the issue syslog with us to check.
