For a short time, I was running Adguard Home externally. To force clients to use it for DNS, I added a command to the above entry in Luci (see screenshot). When I went back to using Adguard home, it was time to remove it.
I have deleted this entry (using the 'x' on the left side), saved this page and saved and applied the parent page. When I go back to check immediately after applying, it looks like it should.
After about an hour, if I go back to check, the entry reappears. At first, I thought it was me and I forgot to save and apply, but that wasn't the case. This entry keeps reappearing.
How can I make this entry disappear once and for all?
admon
August 29, 2024, 5:49pm
2
Check your dhcp config by running cat /etc/config/dhcp
Maybe you forgot to save and apply?
xize11
August 29, 2024, 6:23pm
4
Please restart the dhcp server with /etc/init.d/dnsmasq restart or via luci at system -> Startup.
If that didn't help may i know the contents of /etc/resolv.conf and if exits: /etc/dnsmasq.conf ?
I don't think so, but I just consciously did it (again) a moment ago. Stay tuned.
I ran the command you suggested and got the following:
I just ran the command. Here are the contents of the files you asked about:
resolv.conf :
search lan
nameserver 127.0.0.1
nameserver ::1
dnsmasq.conf :
Change the following lines if you want dnsmasq to serve SRV
records.
You may add multiple srv-host lines.
The fields are ,,,,
A SRV record sending LDAP for the example.com domain to
#srv-host=_ldap._tcp.example.com,ldapserver.example.com ,389
Two SRV records for LDAP, each with different priorities
#srv-host=_ldap._tcp.example.com,ldapserver.example.com ,389,1
#srv-host=_ldap._tcp.example.com,ldapserver.example.com ,389,2
A SRV record indicating that there is no LDAP server for the domain
The following line shows how to make dnsmasq serve an arbitrary PTR
record. This is useful for DNS-SD.
The fields are ,
#ptr-record=_http._tcp.dns-sd-services,"New Employee Page._http._tcp.dns-sd-services"
Change the following lines to enable dnsmasq to serve TXT records.
These are used for things like SPF and zeroconf.
The fields are ,,...
#Example SPF.
#txt-record=example.com ,"v=spf1 a -all"
#Example zeroconf
#txt-record=_http._tcp.example.com,name=value,paper=A4
Provide an alias for a "local" DNS name. Note that this only works
for targets which are names from DHCP or /etc/hosts. Give host
"bert" another name, bertrand
The fields are ,
#cname=bertand,bert
server=/ts.net/100.100.100.100
I'll check this again in a while.
xize11
August 29, 2024, 7:00pm
6
The resolv.conf is fine, for the dnsmasq.conf i have a little problems to read.
If you could please use:
//your code
Then its nicely marked up , is there also a /etc/dnsmasq.d available?
I am not sure what you want to do with the dnsmasq.conf file. It is mostly commented lines (beginning with '#'). The only other line is:
There is no /etc/dnsmasq.d file.
xize11
August 29, 2024, 7:08pm
8
It could be they added a init type of file there which overwrites the default dhcp config, i just wanted to make sure
