Is there a get started guide for Luci? When I go to ...
http://192.168.8.1/cgi-bin/luci
... i am asked for a 'password' for 'username = root'????
It's the same password as for the router and username is root indeed.
And if you ever use SSH, the login is root@routerip with the same password as the admin page too.
Thanks ... that got me a step further ...
but I get an error
"Error - No related RPC reply""
I am connectedf vis WiFi ... do I need a physical connection for LuCi???
Did you update the firmware plugins by using the plugin manager, maybe?
Which 'plugin' is the 'firmware plugin? Is there a guide for setting up vlans?
What did you do before you want to login into luci? I mean, did you change any settings or something like this? Like updating plugins?
Nothing. I got the Flint2 up and running set up a guest net and have one computer connected to router and a couple of entertainment devices.
Looking to isolate the computers from the entertainment devices and the guest network.
