I have a Slate AX1800 and it had been working great for a while.
I am using it with both a T-mobile tablet sim with the appropriate magic applied, and also AT&T but it seems as if it just wont’ connect. it keeps cycling and this is what i get when I drilled into the logs… any ideas?
*****Start
Thu Jan 4 09:52:35 2024 daemon.notice netifd: modem_2_1 (6319): cat: can’t open ‘/tmp/modem.xhci-hcd.0.auto/signal’: No such file or directory
Thu Jan 4 09:52:35 2024 daemon.notice pppd[6574]: pppd 2.4.8 started by root, uid 0
Thu Jan 4 09:52:36 2024 local2.info chat[6639]: abort on (BUSY)
Thu Jan 4 09:52:36 2024 local2.info chat[6639]: abort on (NO CARRIER)
Thu Jan 4 09:52:36 2024 local2.info chat[6639]: abort on (ERROR)
Thu Jan 4 09:52:36 2024 local2.info chat[6639]: report (CONNECT)
Thu Jan 4 09:52:36 2024 local2.info chat[6639]: timeout set to 10 seconds
Thu Jan 4 09:52:36 2024 local2.info chat[6639]: send (AT&F^M)
Thu Jan 4 09:52:36 2024 local2.info chat[6639]: expect (OK)
Thu Jan 4 09:52:36 2024 local2.info chat[6639]: AT&F^M^M
Thu Jan 4 09:52:36 2024 local2.info chat[6639]: OK
Thu Jan 4 09:52:36 2024 local2.info chat[6639]: – got it
Thu Jan 4 09:52:36 2024 local2.info chat[6639]: send (ATE1^M)
Thu Jan 4 09:52:36 2024 local2.info chat[6639]: ^M
Thu Jan 4 09:52:36 2024 local2.info chat[6639]: ATE1^M^M
Thu Jan 4 09:52:36 2024 local2.info chat[6639]: send (AT+CGDCONT=1,“IP”,“fast.t-mobile.com”^M)
Thu Jan 4 09:52:36 2024 local2.info chat[6639]: timeout set to 30 seconds
Thu Jan 4 09:52:36 2024 local2.info chat[6639]: AT+CGDCONT=1,“IP”,“fast.t-mobile.com”^M^M
Thu Jan 4 09:52:36 2024 local2.info chat[6639]: send (ATD99 1#^M)
Thu Jan 4 09:52:36 2024 local2.info chat[6639]: expect (CONNECT)
Thu Jan 4 09:52:36 2024 local2.info chat[6639]: ATD99 1#^M^M
Thu Jan 4 09:52:36 2024 local2.info chat[6639]: CONNECT
Thu Jan 4 09:52:36 2024 local2.info chat[6639]: send ( ^M)
Thu Jan 4 09:52:37 2024 daemon.info pppd[6574]: Exit.
Thu Jan 4 09:52:37 2024 daemon.notice netifd: Interface ‘modem_2_1’ is now down
Thu Jan 4 09:52:37 2024 user.notice mwan3[6646]: Execute ifdown event on interface modem_2_1 (unknown)
Thu Jan 4 09:52:38 2024 user.notice firewall: Reloading firewall due to ifdown of modem_2_1 ()
Thu Jan 4 09:53:04 2024 daemon.notice netifd: Interface ‘modem_2_1’ is setting up now
Thu Jan 4 09:53:04 2024 daemon.notice netifd: modem_2_1 (8087): ls: /sys/bus/pci/devices/: No such file or directory
Thu Jan 4 09:53:04 2024 daemon.notice netifd: modem_2_1 (8087): cat: can’t open ‘/proc/gl-hw-info/sim’: No such file or directory
Thu Jan 4 09:53:05 2024 daemon.notice netifd: modem_2_1 (8087): ls: /net: No such file or directory
Thu Jan 4 09:53:05 2024 daemon.notice netifd: modem_2_1 (8087): The interface could not be found.
Thu Jan 4 09:53:05 2024 daemon.notice netifd: modem_2_1 (8169): Stopping network modem_2_1
Thu Jan 4 09:53:05 2024 daemon.notice netifd: modem_2_1 (8169): Command failed: Permission denied
Thu Jan 4 09:53:05 2024 daemon.notice netifd: Interface ‘modem_2_1’ is now down
Thu Jan 4 09:53:05 2024 user.notice mwan3[8194]: Execute ifdown event on interface modem_2_1 (unknown)
Thu Jan 4 09:53:06 2024 user.notice firewall: Reloading firewall due to ifdown of modem_2_1 ()
Thu Jan 4 09:53:08 2024 daemon.notice netifd: Interface ‘modem_2_1’ is setting up now
Thu Jan 4 09:53:08 2024 daemon.notice netifd: modem_2_1 (8766): ls: /sys/bus/pci/devices/: No such file or directory
Thu Jan 4 09:53:08 2024 daemon.notice netifd: modem_2_1 (8766): cat: can’t open ‘/proc/gl-hw-info/sim’: No such file or directory
Thu Jan 4 09:53:08 2024 daemon.notice netifd: modem_2_1 (8766): ls: /net: No such file or directory
Thu Jan 4 09:53:08 2024 daemon.notice netifd: modem_2_1 (8766): The interface could not be found.
Thu Jan 4 09:53:08 2024 daemon.notice netifd: modem_2_1 (8834): Stopping network modem_2_1
Thu Jan 4 09:53:08 2024 daemon.notice netifd: modem_2_1 (8834): Command failed: Permission denied
Thu Jan 4 09:53:08 2024 daemon.notice netifd: Interface ‘modem_2_1’ is now down
Thu Jan 4 09:53:08 2024 user.notice mwan3[8841]: Execute ifdown event on interface modem_2_1 (unknown)
*****End
Tried on Firmware 4.5, 4.4.6, and now on 4.2.3 and still seeing the same issues.
Tmobile/ATT/visible all act the same and will not connect.
Are there any firmware updates for the m2 board?
