Hi!
Especially @admon. Can anyone, or you please help me to make my MAC be randomly generated after each reboot?
I need some kind of script or instructions. Thanks you!
Hi!
Whose MAC address? wifi?
Of my Gl-Inet router.
You have manual option:
But I need to make it randomised every time it reboots
Do you just need the mac address on the wan interface to be random?
I need to make all visible MACs to be random
Sorry, this feature is not currently supported
That’s why I asked community. Maybe there is a custom script or something…
Nope, no script available.
It shouldn’t be too hard to create one, so give it a try.
@admon, can you check this? I found it on Reddit
#!/bin/sh
# Update package list and install macchanger
opkg update
opkg install macchanger
# Create the MAC randomization script
cat << 'EOF' > /etc/init.d/randomize_mac
#!/bin/sh /etc/rc.common
START=99
start() {
for iface in $(ip link show | grep -E '^[0-9]+:' | cut -d ':' -f 2 | cut -d ' ' -f 2); do
if [ "$iface" != "lo" ]; then
macchanger -r $iface
fi
done
EOF
# Make the MAC randomization script executable
chmod +x /etc/init.d/randomize_mac
# Enable the MAC randomization script
/etc/init.d/randomize_mac enable
# Delete this script
rm -- "$0"
Or this:
#!/bin/sh
INSTALL_PATH="/etc/init.d/randomize_mac"
echo "Creating MAC randomizer script..."
cat << 'EOF' > $INSTALL_PATH
START=99
start() {
generate_random_mac() {
echo $(printf '%02x' $((RANDOM%256)))":"$(printf '%02x' $((RANDOM%256)))":"$(printf '%02x' $((RANDOM%256)))":"$(printf '%02x' $((RANDOM%256)))":"$(printf '%02x' $((RANDOM%256)))":"$(printf '%02x' $((RANDOM%256)))
change_mac() {
local iface=$1
local new_mac=$(generate_random_mac)
ip link set dev $iface down
ip link set dev $iface address $new_mac
ip link set dev $iface up
change_mac $iface
fi
done
EOF
echo "Making MAC randomizer script executable..."
chmod +x $INSTALL_PATH
echo "Success!"
echo "Enabling MAC randomizer script to run at boot time..."
echo "Success!"
echo "Deleting installation script..."
rm -- "$0"
Here is example of output of this command:
Output:
localhost:~# echo $(printf '%02x' $((RANDOM%256)))
a7:03:f2:fa:45:5d
f5:3f:8b:6e:f9:84
e8:db:17:37:29:fd
