Hi.
I have a few PCs on the same LAN and I want to configure them for Remote Desktop (Windows) under GL.iNet router.
I tested the connections on another router and they could see each other, but not on the GL.iNet router network.
Here are some screenshots:
- On main network:
- on GL.iNet (tablet side)
- on GL.iNet (laptop side)
So on the GL.iNet network the devices can only see themselves on the LAN.
Is there a way I can enable network visibility on the GL-AR750 / disable AP isolation?
Or is there something else I am missing?
Thank you!
