Is it possible to turn a GL.iNet router into a print server that will work with a dymo labelwriter 450 printer?
Thanks
Thanks
It is USB printer?
Pls check this post
Thanks for the reply. Yes the printer is normally connected to a computer via USB but we want to connect it to a GL.iNet router set as a print server so multiple computers can print on it at any time.
Do you think this would work?
Thanks ![]()
