Mango constantly crashing
I just got a GL MT300N V2 Mango. I am using in repeater mode to bridge to a single wifi connection in my home (testing for a later co figuration). Out of box, after reset, and after upgrade, when I attempt to use the router, it crashes and reboots itself every few minutes. I’ve tried a few settings permutations eg 20/40mhz to 20mhz and disabled dns rebinding protection. I connect with a single client machine (tried various different devices but independently of one a other).
The product is totally unusable. But I see others apparently using it. Suggestions on what to inspect/change?
What is the model of the upstream router? Maybe some WIFI compatibility issues
I’d try re-flashing, preferably with a newer firmware, if available.
Not sure i understand. I did update to the latest software on the router. It did the same thing before as well as after. Are you suggesting something different?
How does this help me? Its a basic router that everything else connects to except your product. Your product is supposed to be a travel router where you can’t control what you’re connecting to. This is a non-answer with no insight as to how i can diagnose this.
I think the issue was the power supply. Not sure why since its a very low power device, but when a device connects to Mango i think power consumption probably spikes and that took down the router. It may be stable now with a different power supply. Still testing
Not power supply. Added travelmate and back to constantly crashing.
I’ll return this product. Not usable
It is surely the powe supply. Jus change to another one.
