I’ve a Mango configured as an extender to bind a LAN-Only device (printer) into my WLAN via bridge.
The Mango is being switched on/off with the printer. However after some time it frequently looses its WLAN connection and is not more accessible. I’ve to reset and reconfigure manually every time.
This happened 5-7 time since beginning of this year.
That’s not the problem. It works for some time but then mango is no more accessible after booting. Long pressing the reset button and reconfiguring is all that work since the WLAN led is off then and it has no connection anymore. Seems like mango forgets the WLAN credentials
I have the very same issue and it is a disaster that gl continues to ignore this problem. I have had the problem not only with Mango, but also with 2 different Velica routers on 2 different networks and out of nowhere.
Even after completely resetting the box, the wifi password is no longer accepted after the first reboot. My Mac operating system recently reports with Sonoma that the router has changed from WPA to WEP, but the login still does not work!
