Firmware openwrt-mt300n-v2-3.212-0407
Mango GL-MT300N-V2
I’m wondering why the lights for WAN and LAN cable are not working in order to indicate the traffic? are there fake lights?
thank you
Mango GL-MT300N-V2
thank you
Looking from the edge near the LEDs,
from left to right
Power, WAN or LAN, WiFi
Cannot remember if the middle LED indicate wan or lan, or nothing.
But you can configure the LED function from luci, or modify /etc/config/system
Thank you for your reply
But I think I was misunderstood.
All lights WAN, LAN are off in this moment (and I’m talking about lights close to R45 connector, not on the top of the device)
There is no light at the Ethernet port.
Ok got it… so all hole there ,on WAN and LAN where is RJ45 cable are fake one
