It seems to me from what I have read that it should be relatively simple to create a Wireguard VPN tunnel between two Mango routers, yet I can’t get a connection. Have I missed something?
My Mango devices are “MangoHome” and “MangoTravel”.
MangoHome
This is connected by ethernet cable between its WAN port and my router. When I log my computer on to MangoHome’s SSID I can successfully access the internet.
I created a Wireguard server on MangoHome. Status is successful (green symbol). Under the Management tab I created a new user, which I called “Remote”. I generated a configuration on MangoHome for the user “Remote” and copied the JSON output.
MangoTravel
This is connected by WiFi as a repeater to a mobile broadband dongle. When I log my computer on to MangoTravel’s SSID I can successfully access the internet.
I created a Wireguard client on MangoTravel, which I named “Client”. I pasted the JSON configuration from MangoHome into its configuration tab. It indicated that it was successful but when I click on Connect all I get is an amber signal. Is my reasoning correct?
