I just bought Mango a couple of days ago. I put this on my office desk using the Lan attaching to my laptop and Wi-Fi for my cellphone since signal is weak in my position.
However, the router disconnect and reboot quite frequently. Sometimes, I can use this over an hour but sometimes it reboots several times within an hour.
I checked the Lan connection should be fine since I tried to plug the office Lan directly into my laptop and it works well over the whole day. I am not sure what’s problem on my Mango. I use the USB power from the IBM laptop docking and the original Lan cable in the packaging.
Has anyone got the same experience before? Any solution can fix it!
I notice this issue as well only with the latest (stable and beta) version (openwrt-mt300n-v2-3.212) of the firmware. I previously had the version “openwrt-mt300n-v2-3.102” installed and worked without issues.
