Mango router leak
I noticed and I was told that the Mango router when it is configured as a VPN client and for some reason it reboots or turns off and turns back on, while it is starting up, it pass direct internet of your modem for a couple of seconds until it connects back to the VPN server, does not matter the firware version it has on it.
Is this issue for all GL Inet routers or it is only for the Mongo router?
Does anybody has any clue about it?
I tested and confirm it is a problem.
I am filing an internal bug record.
Thank you. @alzhao
But is this issue with all GL Inet router or only with the Mango router?
The bug has been fixed and merged in latest firmware. But unfortunately for MT300N-V2 4.3.18 it does not fix yet.
@alzhao
Does that mean that for other models the bug has been fixed? For example the Flint 1 and 2?
Unfortunately I tested and the bug is still there!
I am pushing guys to fix.
Tested Flint 1 with v4.6.6 several times and don't have this problem.
@alzhao Thank you for that.
Con you please test con confirm the Opal model does not have that issue too?
4.3.19 should have fixed that.
Thanks @alzhao .
Quick question;
with this new firmware, the issue will be fixed in all router model including the Mango one?
For Mango you need to wait for the next release.
