Hi, yesterday I bought the GL-MT300N-V2. After having problems getting it in uBoot (for me it was not clear that it requires 5 led flashes instead of 3) I was pretty pleased with its functions. OpenVPN with killswitch worked great connected via cable. But then I wanted to connect the router to WiFi of another router but I could not get a connection, also the advanced OpenWRT UI didn’t help.
With OpenWRT 19.07.6 it worked but I like the easy to use GL iNet UI so I would be happy if you could help to get it done with the GL-iNet Firmware or release an update.
Thanks!
Edit: Further tethering does also not work with iPhone SE iOS 14.4 via USB.
