As mentioned, I tried to connect to a passwordless wifi, but the gui insist me to put in a password
Hi, which version of the firmware do you use?
3.025 from auto update
other question:
If I choose ‘other’
I can pre-save a password less wifi, but why do i need to specify the channel number ? Shouldnt it be auto ?
It may be a multi-SSID network. Can you take a look with a WiFi analyzer APP?
