Thank you, I have an update.
I have a proxy provider that provides PPTP (1723), SOCKS5 (21, 508, 5080) and Squid (3128, 8080) connections.
I have defined all three servers on the Servers Manage page, using. PPTP (1723), SOCKS5 (5080) and Squid (3128).
On the General Settings page in the Transparent Proxy Section, I set the Main Server to either the Socks or the Squid server and reboot the router and the computer.
Now tracert takes a different path to google.com yet every server along the way still belongs to my ISP.
My Proxy provider’s server(s) don’t appear and now all HTTP and HTTPS don’t work.
I cannot browse any internet pages. HTTPS says it cant negotiate security and HTTP says the server reset the transaction.
Same deadness with either SOCKS5 or Squid. I also tried adding UDP-Relay Server = Same as Main Server. Still deadness.
I can proxy to either one successfully with Firefox proxy settings as well as Internet Explorer proxy settings.
I tried setting all three servers in the SOCKS5 Proxy Section and saw no changes at all. No change to tracert no change to Firefox.
I don’t know what the Port Forward Section is for so, I have done nothing in that section.
There are three pages to the ShadowSocks interface and multiple choices within a page that makes it impossible to trial and error a solution.
Can anyone please provide a working example or simple tutorial that shows what is put in what boxes on what pages in someones example of a working proxy on this router?
It would be especially helpful if this example used a free public proxy service so anyone could directly use the example to prove that their situation works before embarking on changes to their personal situation.
Thank You
