Marble and SQM
@robotluo Sorry for the ping, but in the main post it seems you were the one who solved the issue.
Marble does not yet support SQM.
The Marble hardware does, your official Marble firmware does not.
Marble is better as an extender than a home router in my eyes anyway. So just run SQM on the main router, and then use the Marble in Extender mode.
Marble now supported to install the SQM.
Thank you so much! Thanks to everyone who responded!
Sorry to bother again. I tried installing the packages, but got the following:
Installing luci-app-sqm (1.4.0-2) to root...
Downloading https://fw.gl-inet.com/releases/qsdk_v12/packages-4.x/ipq50xx/packages/luci-app-sqm_1.4.0-2_all.ipk
Installing kmod-sched-cake (5.4.213-1) to root...
Downloading https://fw.gl-inet.com/releases/qsdk_v12/kmod-4.6/ipq50xx/kmod-sched-cake_5.4.213-1_aarch64_cortex-a53_neon-vfpv4.ipk
Collected errors:
 * check_data_file_clashes: Package kmod-sched-cake wants to install file /lib/modules/5.4.213/sch_cake.ko
	But that file is already provided by package  * kmod-sched
 * opkg_install_cmd: Cannot install package luci-app-sqm.
I get the same errors too when I install the package.
are you on the 4.7.2 beta?
root@GL-X2000:~# opkg list |grep sqm
collectd-mod-sqm - 5.12.0-1 - SQM/qdisc collection plugin
luci-app-sqm - 1.4.0-2 - Luci interface for the SQM scripts queue management configuration package.
sqm-scripts - 1.4.0-2 - A set of scripts that does simple SQM configuration.
sqm-scripts-extra - 2016-06-08-1 - A set of experimental scripts for sqm-scripts QoS package. The contents of this package may change as new qdiscs like 'cake' are developed and tested.
same packages available for the Spitz Plus X2000 :slight_smile:
root@GL-X2000:~# opkg remove kmod-sched
Removing package kmod-sched from root...
Updating database.
Database update completed.
root@GL-X2000:~# opkg install luci-app-sqm
Installing luci-compat (git-24.098.23006-f4a76aa-1) to root...
Downloading https://fw.gl-inet.com/releases/qsdk_v12/packages-4.x/ipq50xx/packages/luci-compat_git-24.098.23006-f4a76aa-1_all.ipk
Installing sqm-scripts (1.4.0-2) to root...
Downloading https://fw.gl-inet.com/releases/qsdk_v12/packages-4.x/ipq50xx/packages/sqm-scripts_1.4.0-2_all.ipk
Configuring luci-compat.
Configuring kmod-sched-cake.
Configuring sqm-scripts.
Configuring luci-app-sqm.
Updating database.
installs fine
I downgraded from 4.7.2 beta to 4.5.19 via uboot. Perhaps that could be the reason.
Maybe, I'm on 4.5.23 on the X2000, installed fine.
Perhaps there is something in 4.5.19 that makes SQM fails to install.
Please upgrading to the latest firmware v4.7.2 beta.
Upgraded to 4.7.2 and SQM works fully. Thanks!
