Marble (GL-B3000) firmware 4.5.22, adguard crashes
I have two marble routers setup for family members with 4.5.22 firmware. Even with only one list small enabled, the router locks up every 24-48h and needed to be rebooted. Any suggestions? Seems to be just this specific device as the flint 1, 2, etc that I have setup for others are bullet proof with adguard. As it crashes, the logs get erased. Any suggestions?
Please SSH into the router and run the following command to continuously print system logs and memory usage.
Keep the terminal open, and when the issue occurs, capture and send us the output.
logread -f &
while true; do free -h; echo '-----------------'; sleep 5; done
If possible, upgrade one of them to the latest beta firmware 4.7.15 and see if the issue persists.
Download: GL.iNet download center
Upgrade Guide: Upgrade - GL.iNet Router Docs 4
come join us on 4.7.15
