Hello guys,
Hope you are doing well. I am using a Beryl AX (GL-MT3000) router with Tailscale and an Exit Node ( CHUWI LarkBox X 2023) connected on the same local network using 1Gpbs ports in all devices. Doing a speedtest without any tunnel I can reach 950 Mbps (UP/DOWN).
When the traffic goes from PC -> Beryl AX -> Exit Node. At most I reach 150 Mbps (UP/DOWN) using speedtest-cli. Tailscale ping/status shows the private IPs within my local network (No Derp servers). If I do the same test from my PC configuring Tailscale client to use the Exit Node and plugin the PC directly to my main router (PC -> Exit Node), the speed goes to about 800 Mbps.
I have tried various MTU settings on the client PC but the speed difference is minimal. Any idea where the problem might be? I would say it is the Beryl router, but after many configuration changes I have not improved the speed.
PS: Using version Tailscale 1.66.4 in all devices. All devices are in the same subnet and connected to the same main router (Mercusys AX3000).
Thanks!
